Navman ICN510 GPS Receiver Logo
Anonymous Posted on Dec 10, 2010
LCD not reacting properly so iCN510 can not be used
A
Anonymous
Is it posible to uppdate maps on Navman ICN510
and where do you get it from in victoria aust tell dave.
1helpful
My nokia 5800 XM screen not working properly, I'm touching something its sawing different thing. whats probelm? Nokia 5800 XM screen not working properly, I'm commanding some think, its respond wrong....
You can try calibrating your screen using the procedure at this link
http://www.walkernews.net/2010/01/30/how-to-calibrate-nokia-5800-touch-screen/
It will be difficult to start since your screen is not reacting as you expect it to, but it sounds like the calibration is out of whack.
Navman icn510 will not turn on....it has started twice but screen goes blank.
personally i would change the lithion battery. It seems that you are only getting the initial boost which is all a run down battery would give you.
Maps
I think the best solution, due that it is a non upgradeable model by the official site, you can unlock and install another software.
I have the IGO and goes terrific
1helpful
I think the battery has failed. so how do i change it please
You can buy a new battery in ebay and replace it. It is very easy: unscrew the four screws and open carefully without sd card(look at the phoneplug and sound roll). You will see the battery with its connectors... same as you bought it.
1helpful
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
5helpful
2answers
No instructions
I have a copy of the manual for the icn510.
It's 4 mb and a pdf file.
email me at dave[email protected]
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
