SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
SOURCE: cannot launch vaio recovery center after
Click here for Driver page
Try again to launch the VAIO Recovery Center by following
hope this helps..
If any error occurs while recovery..reply with the error message..
SOURCE: memory problem on sony vaio vgn-ns230e wont do
There is a problem in your computer RAM so replace it with new one.
SOURCE: I am trying to recover
Hi icky2449,
The error 320 and 330 while performing the System Recovery using the Recovery Discs indicates the issue with the Recovery Discs or the Optical Drive. However, the Computer comes with the Recovery Partition present in the hidden partition of the Hard Drive. As the System Recovery process is not working using the Recovery Discs, you can use the Recovery Partition for the System Recovery.
To access the Recovery Partition, please restart the Computer and press the F10 Key. This will take you to the Edit Boot Options screen. At the Edti Boot Options screen, press the Enter Key. This will launch the VAIO Recovery Center. In the VAIO Recovery Center, you can select the "Restore C: Drive" to restore the Computer to the factory settings. (Selecting the Restore C: Drive option will erase all the User data in the Computer and restore it back to the factory settings.)
The Restore Complete System option can only be performed using the Recovery Discs. After performing the System Recovery using the Recovery Partition, you can create new Recovery Discs.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
