I HAVE A SONY VPH-1030Q1/2030Q1 VIDEO PROJECTOR. IS IT POSSIBLE TO REVERSE THE IMAGE TO USE ON A REAR SCREEN APPLICATION? I HAVE IT SET UP OUTSIDE BY THE POOL AND IT WORKS GREAT ON THE DA-LITE REAR PROJECTION SCREEN, BUT THE IMAGES ARE BACKWARDS. IF THE SYSTEM CAN NOT REVERSE THE IMAGE FOR REAR PROJECTION, IS THERE AN AFTERMARKET DEVICE THAT I CAN USE TO ACCOMPLISH THIS? IF SO, WHERE CAN I GET ONE AND HOW MUCH DOES IT COST? OR DO YOU HAVE A BETTER IDEA? THANKS, BILLY MUSSETT, 580-286-6366, [email protected].
SOURCE: nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
SOURCE: Fogging problem (i.e.) screen is foggy at start up but clears 20 to 30 mins use.
what is model number of your Sony tv to provide you info about foggy picture problem.
SOURCE: Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't
when the bulb dies, but when a bulb has lost 10% of its brightness - so
you might well be able to reset the timer and get much more use from
the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
SOURCE: Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
SOURCE: I have a SONY VPH-D50 projector. Screen has green
You will probably need a new lamp.
--- Please dont forget to vote if you liked my answer thanks
thanks
