Question about Polar S150 Heart Rate Monitor
Setting Polar CE0537
I'm hoping you can help me. I have an older heart rate monitor, which I haven't used for quite some time, and now I don't remember how to set the functions. Do you have instructions for this model? It looks like the 150 you show elsewhere on the site. I just want to set the date and time, clear the stop watch, and use it to time laps and see what my heart rate is. Since we replaced the battery, but didn't have a way to seal it, I assume I can't use the watch in the pool. Is that correct?
Thanks so much.
  • 2 more comments
  • aimck Jul 24, 2008
    I am looking also for instructions, as I purchased the same model some years back and moved and can't find the instructions.
  • Anonymous Apr 27, 2009
    What battery do I need for Polar ce 0537?
  • Marilyn Hamerstadt Oct 04, 2013
    I have the same problem and I am wanting to access the user manual.
  • Michael Sadler Nov 13, 2016
    CR2032
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Posted on Dec 27, 2008
3 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: where can i get a MANUAL for polar heart monitor model ce0537
Check the links below:
User Manual
Video instructions
TABLE OF CONTENTS
Posted on Feb 07, 2009
  • 109 Answers
SOURCE: polar ce0537 watch screen goes
Have you had the battery tested? Try that, and we will go from there.Let me know, I can help you it just takes curtain steps to make sure we don't go through a bunch of things we don't have to in correcting this problem.
Posted on Aug 12, 2008
Changing battery
Per the owners manual you should not change the batteries yourself because it is a waterproof system. http://fitness.manualsonline.com/manuals/mfg/polar/f2.html?p=13
http://www.polar.com/us-en/support/service
Oct 28, 2014 | Exercise & Fitness
Polar ce0537 batteries
Hi Garry,
I suggest the first thing to try is to replace the battery.
It uses a DL2025 or a CR2025. Your battery should measure 3 volts, and should be constant. Some batteries will hold some charge, appear OK, but have no power and the voltage drops very quickly.
Check the replacement procedure for the battery. Check the battery flat metal holding strap is clean and in place correctly.
Make sure you can reset the time as this will indicate the heart rate monitor is working
Feb 04, 2014 | Exercise & Fitness
I need to know how to set the heart rate range on my monitor. CE0537
In my tips and tricks page is a link to download the manual for free.
There is also a quick guide to settings on the F6, the F6 has several different types of ranges that can be set, so specific instructions would depend on what type of HR zone you are looking to set and whether it is one, two or three zones.
Jan 25, 2011 | Polar F 6 Heart Rate Monitor, Coal
Have a Polar CE0537 S725 watch.I want to reset my time and all the other settings,please help.
If you go to my Tips and Tricks page, there is a link to the manuals for all Polar watches, including the S725.
To reset anything you need to access SETTINGS. On the S-Series watches push either the top right or bottom right buttons until you see the screen that says settings. Then push the red button to choose. use the right buttons again to scroll to the area you want to set. Keep repeating for every function you want to change.
As an alternative, the S725 connects to software that would have come with your watch, if you are connected to the computer through this software you can reset settings from the software and import them to your watch. The specifics of this are in the user manual.
Dec 07, 2010 | Polar S410 Heart Rate Monitor
Setting an hourly alarm on an F5 Polar heart rate monitor.
The only alarms available to use for that watch is your heart rate for exercise and a daily alarm. Unfortunately it does not have the hourly alarm feature. I wish it did I am a personal trainer and hourly chimes would help to keep me on time but my rs200 doesn't have the feature either. Sorry :)
Apr 22, 2009 | Polar Exercise & Fitness
My Polar HR monitor ce0537 do not pickup Hart rate
Had the same problem. Just figured it out. The center Polar Logo on the strap needs to touch your chest in a firm way. Bend it back slightly so it fits snug on the middle of your chest.
Jan 31, 2009 | Polar S410 Heart Rate Monitor
Polar ce0537 watch screen goes blank or changes time and settings. reset the watch ad it happens again within twelve hours or less.polar heart rate monitor.
Aug 12, 2008 | Polar Watches
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Polar S150 Heart Rate Monitor Logo
12,154 people viewed this question
Top Polar Exercise & Fitness Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
