I have the viper rpn 7752v remote. I was away for a month and the remote completely died. I plugged it into the usb and nothing would happen. I called the installer and he told me a savvy trick. After plugging it into the usb, press the function button. Repeat this several times before it actually turns on. Repeated attempts eventually worked. He said even the manufacture doesn't know why this works. If you still need help you can email me and I'll refer you to a good installer. [email protected]. Tony Madan
you have to unplug it then plug it in and press the function key, then follow the same steps repeatedly.
100% RIGHT TANKS A LOT!!!!!!!!
thnx for the advice guys, this little trick did work.
this sorta worked, but I had to just jiggle the charging chord in the remote's slot. I pushed a bunch of buttons but it didn't work until I jiggled the charger chord into the remote. Then the remote gave off a sound and started charging
worked after jiggling the charging cable in the remote. didn't work until I did that. Once I did that, remote gave off sound and started charging
If the battery completely dies then you can replace it. I sell batteries on ebay.
Or maybe they do know why and they get sick of saying " Read your manual "
If the battery is excessively depleted when the charger is connected, functionality may be delayed while it charges to the minimum voltage required to operate the display, after which normal charging resumes.
