Computers & Internet Logo
Posted on Jun 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba error codes - flashing LED
Flashing LED on Toshiba Tecra 9100. Reads as 01001001 which I believe is 49h but can not find what this relates to.
LaFaye Lincoln
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jun 02, 2012
LaFaye Lincoln
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
2201
Points
12
These code interpretations came from:
http://www.notebookforums.com/t/112339/toshiba-2805-s402-power-light-blinking-orange
The codes are not the same for every model and I don't have anything on the 2805, but many of the codes are similar between models. Normally, this would indicate a problem on the main board (expensive) or the battery board (cheaper). Here is the section from the 5105 manual:
DC IN
Error code
Meaning
10h
AC Adaptor output voltage is more than 16.5 V.
12h
Current from the DC power supply is more than the limit (6.05 A).
13h
Current from the DC power supply is more than the limit (0.5 A) when there is no load.
14h
Current sensing IC is not normal.
Main Battery
Error code
Meaning
21h
Main battery charge current is more than 6.05 A.
22h
Main battery discharge current is more than 0.5 A when there is no load.
23h
Main battery charge current is more than 3.1A when DC IN direct charge is off.
24h
25h
Main battery charge current is more than 0.3A when the battery isn't being charged.
S3V output
Error code
Meaning
40h
S3V voltage is not more than 3.14V when the computer is powered on or off.
45h
S3V voltage is not more than 3.14V when the computer is supports CV and is booting up.
C5V output
Error code
Meaning
50h
C5V voltage is more than 6.00 V when the computer is powered on or off.
51h
C5V voltage is not more than 4.50 V when the computer is powered on.
52h
C5V voltage is not more than 4.50 V when the computer is booting up.
53h
C5V voltage is not normal when the computer is suspended.
54h
C5V voltage is not normal when the computer supports CV and is suspended.
55h
C5V voltage is not more than 4.50V when the computer supports CV and is booting up.
C3V output
Error code
Meaning
60h
C3V voltage is more than 3.96 V.
61h
C3V voltage is not more than 2.81 V when the computer is powered on.
62h
C3V voltage is not more than 2.81 V when the computer is booting up.
63h
C3V voltage is not normal when the computer is suspended.
64h
C3V voltage is not normal when the computer supports CV and is shut down.
65h
C3V voltage is not more than 2.81V when the computer supports CV and is booting up.
PPV output (PCU core voltage)
Error code
Meaning
70h
PPV voltage is more than 1.56V when the computer is powered on or off.
71h
PPV voltage is not more than 0.68V when the computer is powered on.
72h
PPV voltage is not more than 0.68V when the computer is booting up.
73h
PPV voltage is not less than 0.68V when the computer is powered off.
BGVSNS output
Error code
Meaning
80h
BGVSNS voltage is not more than 1.62V when the computer is on or off.
81h
BGVSNS voltage is not more than 1.02V when the computer is powered on.
82h
BGVSNS voltage is not more than 1.02V when the computer is booting up.
83h
BGVSNS voltage is not less than 1.02V when the computer is powered off.
84h
BGVSNS voltage is not more than 1.62V when the computer is suspended.
1R5-E1V output
Error code
Meaning
90h
1R5-E1V voltage is more than 1.80V when the computer is powered on or off.
91h
1R5-E1V voltage is not more than 1.275V when the computer is powered on.
92h
1R5-E1V voltage is not more than 1.275V when the computer is booting up.
93h
1R5-E1V voltage is not less than 1.275V when the computer is powered off.
94h
1R5-E1V voltage is not more than 1.275V when the computer is suspended.
1R8-E1V output
Error code
Meaning
A0h
1R8-E1V voltage is more than 2.16V when the computer is powered on or off.
A1h
1R8-E1V voltage is not more than 1.53V when the computer is powered on.
A2h
1R8-E1V voltage is not more than 1.53V when the computer is booting up.
A3h
1R8-E1V voltage is not less than 1.53V when the computer is powered off.
A4h
1R8-E1V voltage is not more than 1.53V when the computer is suspended.
2R5-SNS output
Error code
Meaning
B0h
2R5-SNS voltage is more than 3.00V when the computer is powered on or off.
B1h
2R5-SNS voltage is not more than 2.125V when the computer is powered on.
B2h
2R5-SNS voltage is not more than 2.125V when the computer is booting up.
B3h
2R5-SNS voltage is not less than 2.125V when the computer is powered off.
B4h
2R5-SNS voltage is not more than 2.125V when the computer is suspended.
1R25-E1V output
Error code
Meaning
C0h
1R25-E1V voltage is more than 1.50V when the computer is powered on or off.
C1h
1R25-E1V voltage is not more than 1.063V when the computer is powered on.
C2h
1R25-E1V voltage is not more than 1.063V when the computer is booting up.
C3h
1R25-E1V voltage is not less than 1.063V when the computer is powered off.
C4h
1R25-E1V voltage is not more than 1.063V when the computer is suspended.
2R5-E1V output
Error code
Meaning
D0h
2R5-E1V voltage is more than 3.00V when the computer is powered on or off.
D1h
2R5-E1V voltage is not more than 2.125V when the computer is powered on.
D2h
2R5-E1V voltage is not more than 2.125V when the computer is booting up.
D3h
2R5-E1V voltage is not less than 2.125V when the computer is powered off.
D4h
2R5-E1V voltage is not more than 2.125V when the computer is suspended.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1741
Points
Anonymous
Level 2:
Champion:
  • Expert 239 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
239
Questions
0
Helped
78773
Points
421
5helpful
2answers
TECRA 9100 service manual
have a toshiba tekra 9100..the problem is that it when i turn it on it indicates that its on but the screen remains off when i try it after a while it manages to turn on bu wont boot sometimes it displaysi/o channel error or it sometimes gets past that but pauses when loading the o.s .what could be the solution for this problem
I search driver toshiba tecra 9100 windows XP
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
TECRA 9100 LED FLASHING 01001110
What a work..... sry --
Find another Tecra 9100 and use that machine for spare parts.
They are very cheap today, 100 euro max second hand, perhaps without HD.
Its the system-board, a chip there.
1helpful
Flashing Charging Light on AC Power
shortage on the motherboard, needs new motherboard.
My Toshiba Tecra 9100 cannot boot. its display message : I/O Channel Error in black screen
seems like the mainboards are screwed
BUT
all is not lost
I Buy toshibas with this fault for my family and send them to a nice bloke (ex toshiba Tech ) who fixes them fo £45 I can get a good working lappy for 75 - 80 quid
search on ebay for Toshiba Tecra 9000 / 9100 laptop repairs
curent auction is 220452652232 @21july 09
2answers
Wireless error for tecra 9100
i have a full set of drivers for this machine but not sure how i cud send to you.
CD-RW/DVD-ROM can not read and CD or DVD
yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Grand Canyon Tech
Grand Canyon Tech
