Here are some general steps you can try to program your remote control:
Determine the brand and model of your remote control. This information should be available in the user manual or on the manufacturer's website.
Turn on your Samsung TV.
Press and hold the "Code Search" button on your remote control until the indicator light turns on.
Press the "TV" button on your remote control.
Enter the code for your Samsung TV. You can find a list of remote control codes in the user manual or on the manufacturer's website. Alternatively, you can try entering codes until you find one that works.
Press the "Power" button on your remote control. If the TV turns off, the code has been programmed successfully. If the TV does not turn off, repeat steps 3-5 with a different code.
If none of the codes work, it is possible that your remote control is not compatible with your Samsung TV. In this case, you may need to purchase a new remote control or contact Samsung customer support for further assistance.
Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...Guide to Programming the ... - Download the Manual - 8 Device Learning Jumbo ...
The codes for Samsung TV include 171, 004, 005, 105, 006, 012, 015, 017, 019, 104, 106, 172. These codes are required to program the Innovage Universal Remote for Samsung TV. You have to check all of these codes one by one. When you will enter three digits of the code then if with the entrance of 3rd digit the LED light goes off then it means that code has been accepted.
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV
Code 1005 for Samsung TV
Code 1006 for Samsung TV
Code 1012 for Samsung TV
Code 1013 for Samsung TV
Code 1015 for Samsung TV
Code 1017 for Samsung TV
Code 1019 for Samsung TV
Code 1082 for Samsung TV
Code 1104 for Samsung TV
Code 1105 for Samsung TV
Code 1106 for Samsung TV
Code 1171 for Samsung TV
Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
