SOURCE: Machine will not run
When I have this problem, I turn the knob back and forth (gently) to try to get the needle to release and lift. I get this error message when the needle has shifted (either in the fabric or from using the machine alot at the needle placement shifts).
check your needle, it probably has shifted a bit.
SOURCE: the top thread breaks (or comes right out of the
Take a look through this comprehensive list of
TROUBLESHOOTING
symptoms and possible solutions, it may also be useful for further reference in other times of need.
Best Wishes
Martyn
Bargain Box in Australia
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
SOURCE: I was in the middle of quilting with the walking
look in your operation manal to show you where the feeddog is
then push the feeddog in the right position
let me know if this solves the problem
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
