Question about Nostalgia Electrics Refrigerators
My grandson has a soft drink vending machine that has quit cooling. It appears that the board on the backside is malfunctioning based on the clicking noise it makes. the larger fan is working but the smaller fan inside the unit dosen't appear to be working. The model is the rvm-560 and the sn# 0806000435. Are the boards available? Is there a method of checking the board and small fan motor? Thanks retro series rvm-560
Seaga hy 900 problems vending soda. The problem column doesnn't vend, although the display says it did until I pay for three cans. Then it vends all three at once.
Dunno if you still need this answered but, I own a few of these and can relate. This model does not come with positive vend sensors. The issue your describing happens when the incorrect shim is used for a drink column. If your vending 3 drinks per row in a drink(D) column, it is recommended you use one of the middle columns as they are stock set to have 3 rotations per full 360 degree column rotation as the motor is setup that way. You can manually change the other columns to handle this and vend small cans but the far left and far right are default set to tall cans and bottles with 2 turns per full rotation so 2 drinks per row etc.
Dropping them all at the same time also typically indicates your using the wrong shims for that drink type. You should be able to find more info in the manual or order the correct shims from healthy you direct
Dec 05, 2016 | Retail Supplies
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
Genesis go380
how come my Genesis will dispense two chocolate bars at a time? Is this a setting of some sort?
Aug 13, 2013 | Selectivend Combo Vending Machine for 14...
I brunt out the circuit borad on my drink o matic dr-3 by useing a ac cord instead of dc power supply i need to get either the part number or where to find the part...or both
Is there any numbers on the power board? From looking at the posts on this machine, it appears that getting parts and support for this are hard to do. Can you tell what parts are bad? Do you have any test equipment? Can you solder?
Mar 18, 2013 | Sharper Image Drink-O-Matic
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
My Drink-O-Matic DR-3 power supply HYS68-12-50 crackles and led light flickers. The machine does not cool. It was a gift and worked about 6 to 9 months.
I have the same machine, my power supply was humming and the light completely went out. I took it apart and tested the dual package diode and found one the of the diodes went bad. I un soldered it and cross referenced it with a different part replaced it and now it works
Jan 11, 2011 | Sharper Image Drink-O-Matic
VENDO PEPSI 407 soda machine
selection number 7 reads sold out but its full i have a vendo drink machine that is electronic and i push the code button to test then select number 7 vend on first button then third button to test vend and it showed an error failed .what else could i try i need some sujestions. please.
Apr 23, 2009 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Nostalgia Electrics Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Nostalgia Electrics Refrigerator Expert? Answer questions, earn points and help others
