Hello, for the descriptions of the colors (red. green, and blue) of the USB video adapter, what you have is a "component video input" also called YUV in which you can only send color difference signals from a device that has the same kind of output, like a DVD player. So, you cannot plug your cam cable directly to them.
Maybe your USB adapter has another input or dongle in which the colors of the RCA jacks are the same as you have in your camcorder. Red: right Audio, Black: left Audio and Yellow: composite video.
Send me back more info of your adapter, like make and model, maybe I can see the specs and add more help in this matter.
Good luck
hi there.
At present, the square connector is what is called an "Optical" connector. It's purely digital and transmits digital data via what looks to us like a RED LIGHT. Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections. The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket. a small round hole that looks slightly larger than a pin head. It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
or this :
Sometimes the colours of connectors vary. Just remember that Red to Red (for right hand side) and White to White or Black To White or Black To Black (for left)
