Someone has accidentally pressed some buttons and locked you into test mode. To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Your machine should now work.
F-03 means that there is a drain problem. Check the drain filter and the drain hose. The drain filter must be cleaned and the drain hose must be set according to the specifications on the appliance's manual.
'f02' normally indicates a problem with the motor or the tacho. Often these kinds of faults with Indesit (Hotpoint, Ariston) are cured by reseating plugs/sockets but require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Remove the lower rear panel of washer, locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Reassemble and test for leaks.
Have some cloths ready to wipe up water from hose.
Hotpoint’s are designed to go into test mode when the start button and
the on/off button are pressed at the same time. If you are stuck in
Test mode, simply hold the start button down until it comes out of test
mode, then hold both the start buttons and the on/off button down until
you see ‘D:end’ (or similar message)."
