Televison & Video Logo
Posted on Dec 22, 2017
I have a Polaroid TV, model 3211-TLXB. My television has audio but no picture. I contacted Polaroid. They informed me that I need to purchase a new control box. The rate they quoted was a little high, especially since I purchased this television in 2008. Can you recommend any sites where I can shop around?
myles harrison
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 22, 2017
myles harrison
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1290
Points
15
Have a look on either e bay or gum tree see if there is a spares repairs cracked screen on there . Cheaper than buying direct
I_Fixed_Ya
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
I_Fixed_Ya
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
255
Points
9
I'd shop at Best Buy. If that TV is from 2008, it's done.
3 Related Answers
Anonymous
  • 56 Answers
  • Posted on Sep 12, 2007
SOURCE: Lost remote
what kind of universal remote are you trying? They're all different
Anonymous
  • 998 Answers
  • Posted on Aug 14, 2011
SOURCE: No Picture sound only Polaroid 3211-TLXB
Sir the problem of your tv has two possibility, the inverter board may be damage or there is no supply to the inverter board. To check the voltage input on your inverter board you should remove the back cover of your tv, the supply input is 24 volts dc. If you can do this let me know.
Paul Bade
  • 1818 Answers
  • Posted on Nov 10, 2011
SOURCE: polaroid 3211-tlxb have power and sound but no picture. It did smell like smoke. Any recommendations? Unit is 2 years old.
If you can see a picture (dim and low contrast) when you shine a light on the screen from an angle, your backlight inverter may have a burned-out part.
After this test, whichever result you get, unplug the set and use your eyes and nose to search for overheated parts. I have found connectors that overheated because of a poor-quality solder connection on the circuit board. Note that parts, particularly resistors, can overheat because of a fault in another part.
It is common for solder connections to deteriorate if they are frequently run at high temperatures. Sometimes circuit boards "normally" turn brown from heat because of marginal thermal design. Check the solder connections on components in the hot areas.
Static electricity precaution: most digital electronics are easily damaged by static electricity discharge. Avoid touching the metal parts of the circuitry unless you first touch the metal frame of the set to discharge any voltage buildup on your body.
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Polaroid 3211-TLXB has funny colored picture quality. Turns on and off fine and sound is fine.What could be the source of the problem??
Sounds like T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2helpful
I have a Polaroid 3211-TLXB -It starts up fine-everything works great - then after 10-15 minutes it freezes + picture goes to crazy grey/white lines + volume goes to maximum-won't turn off-have to unplug -...
hi there, this may helps you a bit. Try to unscrew the back casing. visual check the power supply section. If you notice some electrolytic capacitors are bulgy or bloated, it needs to be replaced with same value and type. Felt the power transistors which one really heats up. Over heating of electronic components or part do affects the pictures. this also need to be replace. doing preventive repairs can extend the lifespan of your TV.
Adding exhaust fan may also lessen the heat builds up on the board. Proper ventilation also helps in the performance of the TV. If this do went well maintain the fan.
Please vote and rate. Good day
2helpful
Hi Guys I have a 32' HD Widescreen LCD TV 3211-TLXB, The TV goes on ok but I have a line down the middle of the screen, on the right the reception is ok on the left side the tv seems to be loosing the...
its possible its coming from the digital board which you can get a a whole to exchange its around 400.00 or so or its the lcd panel which is as much as a new tv if you have a servicer there for polaroid you might talk to them
Only have 3 wall mounting holes on my tv
hi there. i can assist you. here is the polaroid support contact information
http://www.polaroid.com/service/index.jsp
Go to that link and you can work with polaroid directly.
2answers
Picture Size
check your picture setting if it is on zoom, you can set it back to auto cinemal or panorama
Lost remote
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
