How do I adjust the amount of water that flows back into the toilet bowl after the flush. There seems to be too little in the bowl as compared to my other toilets. The tank is adjusted to the water level line and the water connection is turned all the way on with plenty of pressure.
Thanks
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Try lowering the float level. This will reduce the amount of water in the cistern and lower the pressure on the flapper so when you flush the water will not flow as fast into the bowl.
Adjust the float attached to the fill valve. Some simply slide up and down on a racheted adjustment bar. Others screw up and down for adjustment. Flush after each adjustment until the proper fill level is acheived. Make sure there is still a sufficient amount of water at a given level to flush the toilet properly.
Typically this will have if the pump is either not vented at all or lack of air flow on the vent pipe. Most of this units have an 1 1/2" vent connection on top of the lid which should be vented to the open air to allow air to flow in and out of the vent pipe at all times. If you already have a vent pipe connected, disconnect it from the top of the lid and leave the vent connection open to the room so air can flow in and out, then flush the toilet, one flush should get rid of all the solids. Also check the rim of the bowl, water should enter evenly all around the rim of the bowl. If you see more water on one side than the other, then could be calcium build up or an obstruction inside the rim of the bowl.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
