Question about Cakewalk V-Studio 20 Stereo Audio Interface
When I connect my guitar to the V-Studio 20 it doesn't catch the sound. i installed the drivers and everything but it still doesn't work what shud i do?
  • Cakewalk Master
  • 5,603 Answers
Open the "sounds and devices properties" in the PC control panel and make sure the input and output show that the V studio IS the input and output... If not, select those. Often you will find that they have defaulted to the PC internal audio board.
Posted on Dec 09, 2010
Testimonial: "thx"
SOURCE:
Hi there. I bought my friend's Ibanez RG3EXFM1 and the volume knob doesn't work. When I plug it into the amp, I don't get a sound unless I mess with the knob a bit. I opened the guitar up
your gonna prob have to replace knob but try and re sodder the connections. if that doesn't fix it then its your knob that needs to be replaced
Dec 19, 2012 | Ibanez RG3EXFM1 Electric Guitar
Guitar out has no sound
You must connect a short jack cable between the GK2 or GK3 and you normal guitar jack out. Secondly, the switch on the GK should be in the middle, that will give synth & dry guitar simultaneously.
Nov 06, 2012 | Roland Gr33 Guitar Synthesizer
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Aug 06, 2012 | Marshall Amplification Marshall MG15FX...
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
There seems to be something wrong with the lead input socket on my guitar...it only seems to work (i.e. get a sound through to the amp) when the jack is wiggled around in the socket on the guitar and even...
Yeah, sounds like a bad connection. If you are handy, you can take the jack out yourself and determine if it is a loose wire or solder connection. If everything looks fine then you should squeeze the connections togather inside the jack itself. Sometimes it just gets pushed apart and does not hit around the male end secure enough.
Nov 30, 2010 | Fender Squier Standard Telecaster Electric...
Well i dont have a les paul studio i have a les paul menace with the same problem. Hopefully you can still help me. When i plug the guitar in and turn the volume up on the guitar a loud hum appears. ...
OK... Most of the guitars have a PAINTED on shielding in the well with the electronics. Sometimes the electrical connection to this is broken causing hum. Sometimes the connection is by way of the potentiometer shaft nuts and they spin and break the connection. This paint is conductive and often black know as aquadag. Use an ohmeter to verify connection.
Oct 27, 2010 | Gibson Les Paul Studio Electric Guitar
Washburn guitar mg-20 pick up switch position 5 neck pick up no sound or noise humm or anything. all other positions and configurations work?
if everything is standard on that guitar then the only reason that pick up wouldnt work is because its a defective pick up or a wire is disconnected. it may also be possible that the selector switch is bad. take a small screw driver and tap the pick-ups in all positions while plugged in to the guitar amp and the volumes up ( not all the way) just loud enough that you can hear the tapping. you find the bad pick up when you cant hear the tapping with that pick up selected.
Feb 22, 2009 | Washburn Music
Cakewalk V-Studio 20 Stereo Audio Interface Logo
141 people viewed this question
Top Cakewalk Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Cakewalk Music Expert? Answer questions, earn points and help others
