Forget the fuses to begin with - you need to check each wire with a multimeter with the lights and ignition turned on to see whats happening at the plug end.
No multimeter? then get a 12v test lamp - (check first its working when connected to the battery it works). Now start with say the Tail lights on - connect the single wire from the test lamp to earth (a clean solid metal connection - like towbar) and then press the probe end against each wire in turn until you find the probe light turns or not. If it turns on then mark that wire as Tail - now do the same with the Stop light, then each Right/Left Indicator and then with the Brake light - either have someone press on the foot brake or else jam a suitable sized length of wood between the bottom of the steering wheel and the footbrake to hold it right down. You may also have a Reverse light as well.
You must have ignition ON to check, Stop, Reverse and Turn Indicator lights.
Hopefully this will locate each 'working' wire for you. Then you have to connect these to your trailer plug in the correct position - Google on your area if need be to see what pins are connected to what wires else when you plug the trailer in to the plug it still won't work.
Check out this website for pins and colours - make sure its applicable to your country -
http://www.etrailer.com/faq-wiring.aspx as it may differ from country and vehicle..
If you find any wire that does not light up when probed - then check the fuse for that wire's use - ie. Tail etc. If that fuse is ok then check back from the plug to the fuse box as you may have a broken wire or disconnected plug. You will always have an Earth wire - this will not light up when probed - its colour is normally white.
