If you are using IE 7/8 you can try to run the program without loading any add-ons to see if one of them is causing the problems. To do this, click Start -> All Programs -> Accessories -> System Tools and then click Internet Explorer (No Add-ons).
(You can also load IE without add-ons by clicking START --> RUN and then typing iexplore.exe -extoff)
If those don't work try to re-register IEPROXY.DLL by clicking START --> RUN and typing regsvr32 IEPROXY.DLL and then clicking OK.
When IE dissapears does IExlorer.exe show in the task manager's list of running processes?
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
SOURCE: internet cuts out
First off, try running disk cleanup to clear your temp files and browser cache. That may help.
If you check your network connection when this error occurs, and it is connected, this could be a sign of what's called a browser hijack, a sort of malware infection. There are some things that install on your system and prevent you from accessing sites that they deem harmful (to themselves)..
For example, can you go to windows update and update your system? Is your antivirus updating successfully?
If not, I recommend you go to www.malwarebytes.com and download their free Anti-malware software, update it and run a scan of your system. Allow it to fix anything it detects.
It will automatically save a logfile.
Then run a full scan of your system with an updated AntiVirus scanner.
You might wish to consult this link as well, if you have any further problems...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
