HP Pavilion Elite m9510f PC Desktop Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A fan is making a horrible noise - HP Pavilion Elite m9510f PC Desktop
Anonymous
Level 2:
Genius:
  • HP Expert 1,325 Answers
  • Posted on Dec 09, 2010
Anonymous
HP Expert
Level 2:
Genius:
Answers
1325
Questions
Helped
344457
Points
292
Hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Anonymous
Level 3:
  • HP Master 32,281 Answers
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7912751
Points
102259
The CPU fan or the fan in the switch mode power supply is faulty.
OR
The CPU fan blades is hitting some wires inside the case or the fan bearing is faulty..
Remove the cover from the desktop case and see if the CPU fan is clear of obstructions.
Check the CPU fan spins freely, if not then replace the CPU fan.
If the power supply is faulty then replace the switch mode power supply, unless you know what you are doing. Mistakes made inside this power supply can be fatal.
When the vacuum is turned on, it makes a HORRIBLE noise. I thought the belt was bad. Removed it, looks fine. Turned on the unit w/o the belt/roller brush. Same noise. I don't know what else to check. Help...
You have probably broken the motor fan. An out of balance fan creates a great deal of noise and vibration. Fans are inexpensive, but require a good deal of disassembly for replacement.
Fan blades will not move when first turned on then when finally get going fan makes horrible rattling noise
Either the bearing on the motor has gone bad or maybe a little spray of w40 may solve the problem. Provided the fan blade is not touching anything.
Jun 26, 2010 • Dryers
HORRIBLE NOISE!!
call tech or installer and check condensor fan assuming noise is outside. shut down outdoor unit and hand spin the fan blade to see if it is rubbing
Commercial cabinet vent fan suddenly starts making a horrible noise as though something is stuck in the fan.
It sounds like the fan bearings are shot. You will have to replace the fan to get the peace and quiet back.
My dryer was making a horrible scrubbing noise and now won't dry
My 14 yr. old Maytag dryer made the same type of noise. It was the fan. The plastic had broken loose around the shaft. As the shaft turned fast, the fan turned more slowly, hence the noise. Replaced the fan ---- perfect drying and no noise. $26.00 for new fan.
Jan 02, 2009 • Dryers
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
2answers
Samsung HLP4663W 46 in. fan noise
you may have several problems but the one I know for sure is the fan noise you hear is not the fan but the color wheel, the barring is screeching. you may need a lamp as well. if you are not a tech DONOT ATTEMPT THIS REPAIR leave this to the pros.
1helpful
2answers
Horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
