NewAir AC14000H Air Conditioner Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We just purchased this product, it was blowing warm and and now wont blow warm air
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 09, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
952990
Points
6173
Check your thermostat setting at +29 and also mode in "Heat ". If still problem continues, check RV
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
My ac wont turn off and only blows at one speed
faulty resistor won't make it blow warm air.
sounds like the climate control is bad.
My heater won't blow out any air unless it is on high with the fan blowing.
Hello let me verify.
1 heater wont blow out warm air unless on high?
possible clogged airfilter.low on coolant or antifreeze.
2 heater wont blow any air unless on high?
Could be a bad switch low ane med do not work.
No heat jaguar 88 xj6 fan wont turn on cool air out the defrost vent
I have the similar problem with both my Jaguars, one is a 1988 Jaguar XJS, the other is a 1987 Jaguar XJ6, both blow COLD air out some vents while it blows warm air for heat. I heard it had something to do with the cold air blowing as a dehumidifier, I don't know if this is true, but it is really annoying to have both cold and warm air blowing when I need heat in these cold Canadian winters. If you find out please drop this website a note and let us know how you solved it. thanks.
2answers
Air conditoner quit blowing cold air while driving home
you can try recharging the system...it's a fairly simple process and freon can be purchased at any parts store. here is an overview:
http://www.aa1car.com/library/ac_recharging.htm
1helpful
2answers
Air conditioning system blows warm air
Ok I've been around too long...R134 (freon replacement product)
Heater wont blow warm/hot air
check your radiator coolant, thats what I did and it blows warm again
Top NewAir Heating & Cooling Experts
Paul Carew
john h
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
