LG LMVM1935 Convection/Microwave Oven Logo
Posted on Apr 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LMVM 2055SW that started having the light in the microwave not turning on when the door opens. Then recently we noticed when turning on the microwave, there is a noise within the microwave, not the normal one and the light and carosel doesn't work. A little wack above the door handle caused the light to come on, the carosel to move and we hear the normal noise. Next time, the wacking doesn't work and I'm guessing one of the door switches. We tried unplugging and replugging the AC, and everything else works. Any ideas? Thanks in advance!!
William Miller
Level 3:
  • LG Master 9,179 Answers
  • Posted on May 07, 2017
William Miller
LG Master
Level 3:
Answers
9179
Questions
Helped
4479592
Points
21747
My help file on door switches is here:
http://www.microwavecontrol.com/doorsw.htm
The service manual is at my site here:
http://www.microwavecontrol.com/lmvm2055_sm.pdf
If you need more free help, free free to contact me directly.
- William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
4 Related Answers
Anonymous
  • 317 Answers
  • Posted on Jan 26, 2008
SOURCE: No key's work. Display and inside light is working
The Keypad is either faulty, or disconnected. Open the case, and remove the screws, holding the outer shell on. Inside, there should be a small board that covers the Keypad. Check to see if there is a ribbon cable, or some other type of connection going from the board to another part of the microwave. If all of the wires are connected, then you will probably need to replace the keypad.
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 27, 2009
SOURCE: Microwave Does Not Heat.
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Anonymous
  • Posted on Jul 22, 2010
SOURCE: LG Microwave won't turn off
Our LG did the same thing - called customer service and they told us the open and slam the door 10 times. It actually worked! It reset the switches somehow.
Anonymous
  • 4 Answers
  • Posted on Mar 27, 2012
SOURCE: Installation of magnetron
if you push the star button and no sound or anything comes from the unit then you have a bad user control. if you hit start and the machine starts working but not heating then i recommend replacing the magnatron capacitor and diode. use caution replacing these as the unit runs the mag with a 20,000 volt transformer
Testimonial: "WOW!! I can't believe someone answered so quickly. OK, can I replace the user control myself? If so, how. OMG you are awesome, thanks so much."
1helpful
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
2helpful
LG LMVM 1935SB doesn't heat.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See this file for more help on door switches.
The service manual for your oven is here, but does not contain part numbers.
If you only need a switch, you can order a universal type here for $5 postpaid.
For other part help, contact
Encompass here or call call them toll-free at 866-779-5835.
Let us know if we can help you further.
3helpful
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Turns on by itself and turntable does not rotate
You may have a control board issue. Thank God for safety switches.
This is a problem that an integrated circuit tech. can repair, but it may be costly.
Decide how much you want to put into this oven vs. buying a new one.
Contact me once you decide and I can help you find a service center.
Thank you,
Dave E. (Illeagle)
2answers
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
