Question about Stanley 3in1 Tripod LED Flashlight 95155
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Posted on Nov 25, 2011
  • Robert Papa Aug 06, 2012
    thank you that was easy lol
  • MiMiKK Sep 16, 2012
    HAAAAhaha !! Ditto !!! It was like "rocket surgery" until we read your instructions !!
    New Friend:
We have one as well but the battery compartment is in the legs of the tripod. You have to unscrew the black foot from the silver tripod leg and insert three AA batteries into each leg.
Posted on Dec 31, 2012
    New Friend:
Thank you for this information, I could not find how to release each torch and replace the batteries anywhere else :-)
Posted on Oct 24, 2014
SOURCE:
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
How do you chance battery on a stranley tripd flashlight
unscrew the caps at the bottom of each leg - each leg holds 3 AA batteries (9 total)
Jan 05, 2013 | Stanley 3in1 Tripod LED Flashlight 95155
What is the purpose of the screw at the base of the 95155 stanley 3 in 1 tripod flashlight
The pin has 2 magnets on it. When you hit the open button it pushes the pin down and releases the legs.
Aug 23, 2012 | Stanley 3in1 Tripod LED Flashlight 95155
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
How do i install batteries on stanley 95-112 tripod flashlight
I just found it! The batteries go into the tripod legs! genius
Dec 30, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have maxlife 369 tripod. how do i put in new batteries
unscrew the caps on the bottom of the legs - each leg has 3 AA batteries
Dec 29, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Where do the batteries go in my stanley tripod flashlight?
Hello, The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck! Rich L.
Nov 28, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
How do I accesss the batteries in my Stanley 3in1 tripod?
Unscrew each leg at the bottom and insert three AA batterys in each one.
Aug 13, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have been given a stanley 95 111 flashlight. dont know how to replace batteries did not get a manual with it
You can remove either the cap or the end and replace the batteries that way. They twist counter clockwise.
Jul 19, 2010 | Stanley The Work Bostitch Security Pocket...
Stanley 3in1 Tripod LED Flashlight 95155 Logo
12,987 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Richard Lilja
Richard Lilja
oldhess
Darrin P. De May
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
