I have a Whirlpool Ultimate Care II Model - LSQ8511KQ0 washer. The clothes wash fine until it reaches the rinse cycle. After the water is full, the rinse cycle does not start and nothing happens. Please help !!!
- Vipul
Sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
I had same problem. Took back control panel off( 2 screws in back), then disconnected the cable that went from the panel to the machine. Then followed that cable to the little hole near where you throw close in. Remove it(two screws). Get that part from appliance store. Have the model # from the machine. I have an Ultimate Care III. Put back together. close the lid. boom. The part is called a "lid switch" good luck
rinise cycle does not start, manually advancing does not work either.
