SOURCE: hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
SOURCE: hobart d-300 mixer
If it is a three phase machine, switch any of the two hot leads to reverse the motor rotation. You can switch them either in the plug or the receptacle.
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
SOURCE: Hobart mixer A200 Rotation
I have a hobart a200 20qt mixer. the flat bitter is scraping the botttom of the bowl. The shaft looks little bend and i think it is and that is what's scraping the bowl at the bottom on one side only. the whole bowl is not being scraped. it used to work like that and now it does not work at all. the motore is running but the gears are not turing the mixer. Before the first geard stoped working but the other two were okay, now none of them work, but the motore is working.
