Question about Panasonic KX-T7730 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
  • 225 Answers
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Posted on Dec 08, 2010
SOURCE:
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
I have a panasonic kx-t7730 phone. A techie set up call forwarding from the phone to another extension, and now I can't remove it. Can you help?
From the intercom, dial 7100 or 710#. Call forward codes are set via 71x and the extension plus #.
This is the TA series code set. The bigger systems have 710x codes.
Carl
Mar 29, 2011 | Panasonic KX-T7730 Corded Phone
How to set name and contact number on the telephone set for one touch dialing with right buttons? My set is Panasonic KX-T7730
It depends on what happens when you dial "9" from the intercom. If it gives you a line, then that's your "access code". If it gives you a line that doesn't exist, then you need to fix your programming.
From the idle phone, press PROGRAM, one of the right side buttons, and dial 9 and your number and STORE. You can program one or all 12 buttons at once. When you're done, pick up the handset and drop it back down to exit programming.
That's it.
Carl
Feb 13, 2011 | Panasonic KX-T7730 Corded Phone
How to lock Panasonic kx-7730 telephone set
If it's connected to a TA series box, on the intercom dial 77 xxxx xxxx #, where xxxx is the same 4 digit number. That will lock the phone. It's unlocked with 77 xxxx, the 4 digit code you used to lock it.
You can review the procedure and conditions in the Operations Manual (OM).
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
Hi i m using th Panasonic KX-T7730 Phone. The light (RED)on top of the instrumernt is lighten always. Why??/If i press the button PROGRAM is asks for some PITS code or something. Can u pls clarify why???
the light is lit red because you have a message (it is the message waiting light)
if you want to get rid of the light, try either INTERCOM *700 then your extension number, or INTERCOM 700 your extension number
as for programming, if you press program, it wants to know what you want to do, so it asks you which feature you would like to program in the form of a 3 digit number
Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
KX-T7730 Corded Phone: WHEN THERE IS AN INTERNAL INTERCOM ACTIVATED TO AN...
Make sure the Auto Answer button is not lit on the empty desk phone, then you could use either 40 to answer all calls, or 4+ the extension number to absolutely answer that phone.
May 06, 2010 | Panasonic KX-T7730 Corded Phone
Resetting the Panasonic KX-T7730
go to menu .... settings.......rest. factory setting..
your security code is 0000 or 1234
try both code one by one.
when u change the code remember the new code.
Jul 28, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
4,425 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
