GE Spectra JBP78 Electric Kitchen Range Logo
Posted on Jan 25, 2018
Broiler Element Replacement
I am trying to replace a damaged broiler (upper) element in my GE JBP68SHSS Electtric Range. I have taken out the damaged broiler element and replaced it with a new one, but I am unsure of what to do with the middle wire that is connected to a prong-like attachment. Can you advise me? Thanks
  • Steve Pack
    Steve Pack Jan 25, 2018
    Hi RCutwright, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    It should have only 2 wires Where was the third wire connected . The element has only 2 connectionshttps://www.partselect.com/PS249284-GE-W...
5 Related Answers
Anonymous
  • 131 Answers
  • Posted on Mar 31, 2008
SOURCE: replace broiler element
Heater elements don't have any colors on the terminals. They will work any way you connect them.
In general, wires are always connected to wires of the same color.
I am concerned that you may be doing something other than replacing the broiler element. If so, it is very important to return the machine to the way you found it. If you can't remember what that was, you should call a professional repair technician.
Anonymous
  • 1543 Answers
  • Posted on Dec 14, 2008
SOURCE: GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Eric Campion
Affordable Appliance Parts
  • 117 Answers
  • Posted on Feb 15, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Anonymous
  • Posted on Apr 09, 2009
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Raphael11
Raphael Gutierrez
  • 54 Answers
  • Posted on Jul 14, 2009
SOURCE: The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
2answers
Upper oven will not heat up, broiler does not work.
Hi Larry
Use a multimeter on AC range to test for voltage on wires going to bad element.
It's probably a bad switch or open element.
Elements often unplug for replacement. Don't always show damage of burned out conductor. So... Use your multimeter on the ohms scale to test for continuity at each end.
Upper oven element is likely open circuit and will need to be replaced.
Cheers
Why doesn't GE JBP24 preheat?
Not familiar with this exact range, but it could be a couple of things.
If the broiler (upper) element heats properly and the baking (lower) element works properly, then the issue is probably in the controller/preheat switch.
If the broiler doesn't heat up, then the upper heating element.may need to be replaced.
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
1helpful
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Broiler works, but oven does not.
oven is equiped with two elements one,< upper > for broiler and the second < lower > is for baking . The bake element is probably damaged and no longer working,< damage is just from use the element has failed >, to know for sure element has to be tested for continuity to confirm this,< unless it is obviously damaged, broken or burnt and seperated >.
1helpful
Broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
