Solution one: Reset the product
If
there is static interference, or loose connections with the product,
this can result in bands or lines in the copy, fax, or scan output. To
resolve this issue, check the product connections and reset the product Press the Power button (
) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (
) to turn on the product.Try to copy, fax, or scan again.If these steps
resolved the issue
, you do not need to continue troubleshooting.If the
issue persists
, continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If
the scanner glass or the white underside of the lid has fingerprints,
smudges, lint, dust, or other debris, this can slow performance and
affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION:
Use
only glass cleaner to clean the scanner glass. Do not use cleaners that
contain abrasives, acetone, benzene, or carbon tetrachloride. These
substances can damage the product. Avoid isopropyl alcohol (rubbing
alcohol) because it can leave streaks on the glass.
) to turn off the product.
Lift the scanner lid.
Figure 3: Lift the scanner lid
Spray a clean, soft, lint-free cloth with mild glass cleaner.
CAUTION:
To protect the scanner, do not
spray the glass cleaner directly on the glass.
Clean the scanner glass with the lint-free cloth.
Figure 4: The scanner glass
Clean the glass strip next to the scanner glass with the lint-free cloth.
Figure 5: The glass strip
Dry
the scanner glass and the glass strip thoroughly with a clean, dry
cloth or chamois to prevent spotting, and then dry the white underside
of the scanner lid.
NOTE:
Do not use paper-based wipes or tissues that can leave fiber residue.
Clean the white underside of the scanner lid.
Figure 6: The underside of the scanner lid
Close the scanner lid.
If the product does not turn on by itself, press the Power button (
) to turn it on.
If these steps resolved the issue
If the issue persists
Solution three: Clean the automatic document feeder (ADF)
Use the following steps to clean the automatic document feeder.
Step one: Clean the ADF rollers and separator pad
Gather the following materials:
A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
Distilled, filtered, or bottled water (tap water might damage the product)
Remove any documents from the document feeder tray.
Lift the cover of the ADF until it stops.
Figure 7: Lift the ADF cover
Find the pick rollers and separator pad.
Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the separator pad.
