System error e225
How do u solve this problem
Hey!Its a lamp error!Best is to have it replaced!Good Luck!
Where would you find the replacement lamp? I have the same error.
Easiest is to contact the local canon dealer and ask them for a quote?If in south africa you can call part serve too!
Good Luck!
I think it will be better to re-connect the flat cable to CIS unit first. Then do the Hardware TEST IN service mode.
Press Additional function >#> go to H/W test using arrow keys, press 1,2,3,4,5 keys , the cis will glow in different colors corresponding to each keys. if this is happening then your CIS is ok. Now your problem lies in the FLAT CABLE OF CIS. Now apply white grease or something like that to the areas where the cis touches the base plate and to th bending portion of cis cable your problem will be solved for sure
what is cis
contact image sensor or scanner lamp
E225 = CONTACT IMAGE SENSOR (CIS) Lamp has a fault. Need to replace CONTACT IMAGE SENSOR UNIT bat not solve problam
