Computers & Internet Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to hook up my ferrari 1000 series acer laptop to a alienware HD monitor but it seems that i couldnt hook it up! the screen is not responding on the HD monitor.What should i do? Do I need to change any settings on my laptop?
Anonymous
Level 2:
New Friend:
  • Expert 37 Answers
  • Posted on Dec 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
37
Questions
Helped
3457
Points
113
Yes after connecting your pc just right click on your desktop and goto properties then select settings column there you will see two small screens select the one written as alienware hd monitor.
and if it not shows up the second screen .then after conecting your monitor cable to laptop just update the monitor driver on your laptop after connecting to internet.
Why my acer ferrary one 200 turn on, but no monitor/display, no hdd led flashing
If you are able to hear the fan running inside your laptop , then it should be possibily the mother board that needs to be checked.
Ferrari 1000 LCD failer
Hi, Your post "Would a failed Inverter on an Acer Ferrari 1000 cause the system to not recognize the installed LCD?" No,the inverter only provides the high freq high volt for the backlight. Monitor/LCD recognition is part of your video/display controller. Pls check your video drivers (ATI Radeon Xpress 1150). Also your Default Monitor Properties. Hope this gives you some idea, Good luck and pls post again how things turn up. Kind regards.
1helpful
1100 ferrari acer power but no screen?
Assuming no BIOS is displayed
  • Memory could be bad
  • Motherboard could be bad
  • Backlight could be bad
  • Inverter could be bad
  • Screen could be bad
Pull the memory modules out and boot the computer if it makes it to BIOS and then beeps at you one or more of the memory modules are bad, replace one at a time if you have more and test until it breaks again then you know which to replace.
To Test the inverter and backlight hook up an external monitor and boot the computer. If it displays correctly on the monitor then you've narrowed it down to a bad screen, inverter or backlight. Backlights don't usually go out.
Remove the monitor and boot the computer. Shine a flashlight on the screen and look for a very faint image of what should be displayed. If you see one I'd start by replacing the inverter. If you don't see one the screen is bad.
If none of this worked then replace the motherboard.
Just got second hand ferrari 1100 and it just has black screen?Used F8 to get the harddrive light and put CD in which is spinning but still black creen also tried external screen?HELP PLSE?
If your external monitor isn't working, it may be your graphics. You could open the case and search for loose connections or components. It's difficult to say without opening the laptop. Your specs say you have integrated graphics. What kind of noises? Is it coming from the HDD? the DVD rom?
Hairline in my acer ferrari monitor
it is a sign of damage to the LCD screen. it cant be repaired, solution is buy for new LCD replacement that matches your model
After bootup, my Acer Ferrari 1000 display bottom half blurrs and then computer locks up.
That is good information, especially when you consider the endless possibilities.
1helpful
2answers
Hi i have an acer 4000 ferrari. but theres no image on screen when you turn it on.any ideas?
possibly video card has problem .or possibly your monitor is not working try using external monitor to see if that is the problem .good luck
1helpful
2answers
Trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
I have a Acer Ferrari 4006wlmi it boots and
Hi...
You need to reinstall the OS.
Let me know
Thanks
Smith
Wifi
Grand Canyon Tech
Grand Canyon Tech
