We have had our new tv for about 6 months and this morning the channels won't change. What do we do?
Press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Power off the set. Unplug it and wait about 5 minutes, Hold the power button on the set for 30 seconds and then plug the TV back in. It should work fine now.
This is the TV reset process, your custom settings will still be there.
Try unplugging the set for a couple of minutes then plug it back in and do a auto program from your menu. that should do the trick
Press orange button V button in the middle of the control go to the wrench click on the orange button and go to system reset and press right to select then press setup wizard and it will scan all your channels again then your control should work cause it work for mine.
I have the same problem. Along with it, the digital channels don't come in at all, just a blue screen. 3 months ago was the first time this happened. We unplugged the tv for a minute and when we powered the tv up it worked like original. Now unplugging it does not work at all. Any other ideas?
I'm having the exact same problem on my 37 in. Unplugging the unit did not help me. Aside from not buying a Vizio, any suggestions would be appreciated.
How do i get to the auto program menu?
We the same issue. Just got the TV and the remote will not operate the channels.
I can't change the channel using the channel + or - button on the remote or on the T.V. itself. I can change the channel when I punch in the correct number for the channel though.
I have the same problem with my 37 inch, had it for about 9 months nothing seems to make it work. I no longer have my receipt any suggestions to what i should do?
Our remote will not change the channels. It works on everything else. Please help!
