Does the Hobart H-600 get 4 speeds by running the elec motor at 2 different speeds combined with a 2 speed gearbox? We just bought one, and is sounds like the elec motor runs faster in 2nd and 4th speed than in 1st and 3rd speed. The beater speed is faster from 1st through 4th, just like it is supposed to be. This is a single phase 240V model.
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
What'd ya do to that poor little workhorse? You need a Hobart service guy. The power is not getting from the switch to the motor. Could be a disconnected wire (on the simple side), could be the start capacitor. Did you turn the timer on? If you don't the mixer won't run! That is a 220V, don't stick your hands in there when it is plugged in.
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
