SOURCE: I can't connect my bt-15k2
Hi desireeveiga,
I see that you need assistance in getting your BT heatset to your LG phone.
make sure that the BT headset is set to discoverable mode, I believe there is a connect button on the headset that you can press and hold down for a couple of seconds this should lit up a light meaning that the BT headset is ready to be discovered by a device.
Once the Headset is set to be discoverable you can try and get you LG phone to detect the headset, Once detected the pairing code should be standard try 0000 this should get the BT headset connected to you LG phone.
I hope that this can help.
Have a nice day,
mvincentc
SOURCE: BT-15K2 doesn't seem to hold a charge.
It is using Li-ion battery.Its life is short.If available try to replace it is the only solution.
