Expert
- Posted on Dec 07, 2010
Re: Maytag Quiet Series 300 - it seems like the soap door...
- Be sure that you don't have something large blocking the dispenser door like a cutting board.
- Make sure the water temp is 125 degrees going into the dishwasher. Cold water won't break down detergent correctly.
- Make sure your getting water pressure: Run your dishwasher on normal. Wait until the cycle starts and the spray arms are spraying. Turn a cup right side up to catch water on the top rack if you run the dishwasher and wait 20 sec that cup should be half or full. If you don't have water in the cup you could have poor water pressure from your pump. This could indicate 1. Worn motor 2. Clogged pump
Have a great day!
