Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition
Check/Repair
Digit Failure Code2
F1
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
Replace oven temperature sensor
F2
Oven temperature sensor shorted
F3
Oven too hot
F3
Clean temp too hot
F5
Check door/latch switch
Replace switch if defective
SOURCE: Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
SOURCE: I have a whirlpool accubake duo, super capacity
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
