Broderbund American Greetings Creatacard Platinum 8 for PC Logo
Posted on Dec 07, 2010
Create a card 3 will not install in new computer with 64 bit windows 7 Please help i have your newer versions and this is my favorite
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
540
Points
I have Createacard 3 installed an running on Win 7 64 bit - however - you have to install XP Mode first which is free from Microsoft if you have Win 7 Professional or Ultimate (not Home). I now have an icon on my desktop that I double click and Createacard 3 loads and works fine.
1helpful
What are the proper steps to take in upgrading a laptop from windows home premium 32bit, to win 7 professional 64 bit ?
First you need to know if the laptop is compatible with the 64 bit system. I bet it might not be and even if it is, then make sure all 64 but drivers are available for all the hardware you intend to use.
The 64 bit OS is of little use as there is so little software to take advantage of it as of yet. Drivers for harware is a good reason to not put 64 bit on any computer- laptops are even more slow in this development of drivers.
3helpful
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
2answers
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Driver conflict with windows 7 64 bit
This version does not support Windows 7 64bit. You will have to purchase a newer version.
Alternatively, install Windows 7 32bit.
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
1helpful
I just purchase a dual core 64 bit window 7 computer but for some unknown reason its not installing the sofware properly, I had changes the new computer 2 times thinking that the problem was the computer ...
You have to get 64-bit Windows 7 drivers for your printer and other accessories, and many programs have a 64-bit version also. Did you download the 64-bit Windows 7 version from Kodak? That's the one you need.
PlanetAMD64.com has good information for you and many drivers listed.
http://www.planetamd64.com/index.php?s=555a2f221ca0b5d3acc03584dd3cb2f1&
Good luck,
Gene Tuck
1helpful
My printer will not print black ink i just changed 3 cartridges
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
3answers
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
1helpful
2answers
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
