Refrigerators Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type of freon does the walk in refer take
jesus360506
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 09, 2012
jesus360506
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
389
Points
Look on the compessor it should tell you what kind but most taker134a
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Dec 07, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
579995
Points
4327
How about a compressor model number. This will identify the Refrigerant used.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
389
Points
Model # CPB050DW we need to know what kind of freon
What do I use in port
If you are referring to the AC system it takes Freon. There are several different types available so make sure you use the proper one for your car. Depending on the year make & model. Also make sure Freon is your problem & don't overcharge it & use the proper gauges.
2answers
WHAT TYPE OF FREON TO USE 2001 L SERIES
134A There should be a sticker in the Radiator support. Or you can reference you owners manual. It amount of 134A should be given for the system.
1helpful
What is total charge for up right freezer
Hello jharrislaye -If you are referring to approximately what the retail price is for this particular product, unfortunately base on the age of the unit, that information is very difficult to find. However, similar units manufacture nowadays is roughly about $700.00-$1,000.00. If you are speaking about a Freon charge, that would be base on the type of Freon the unit requires and on the actual service technician providing the service. You may locate information regarding the Freon on the serial tag, which is typically located inside the cabinet on the left side wall.
How do I recharge my commercial ice maker?
BY RECHARGING I ASSUME YOU'RE REFERING TO THE REFRIGERANT CHARGE.... ITS BEST TO CALL A PROFESSIONAL YOU'LLL NEED REFRIGERANT GUAGES, CHARGING SCALE, VACUUM PUMP, RECOVERY UNIT(IF IT HAS FREON IN IT), MICRON GAUGE, JUG OF VIRGEN FREON REFER TO THE NAME PLATE DATA ON TYPE OF REFRIGERANT NEEDED.... I HIGHLY RECOGMEND A PROFESSONAL DO THE WORK
1helpful
Where do i ad freon to my chevy equinox
You shouldn't ever have to add freon to an a/c system. It is a closed system - like your refrigerator. When was the last time you added freon to your refrigerator or home a/c when there wasn't a problem?
If you are needing to add freon, then you have a leak somewhere that needs to be repaired. Your local automotive technician can diagnose the problem for you. Freon should only be added by trained professionals. If you don't know what you are doing, you can charge the system incorrectly causing significant damage to the system.
If you still want to do it yourself, reference this article.
You will need a set of A/C Gauges, and freon.
Do NOT put any type of stop leak into the system - this can cause irreversible damage to the compressor.
1helpful
Air condtioner has a bad smell causing headache
Whether as a gaseous or liquid coolant, Freon aids in refrigeration, air conditioning and maintaining aerosol contents under pressure. Not only can this toxic chemical expose the earth to excessive ultraviolet rays, but the substance can also sicken those who inhale it in an enclosed atmosphere.
Detecting the signs and symptoms of a Freon leak will protect lives, ground water and air quality.
Cardiac arrhythmia can signify the presence of leaking Freon. A person without a history of irregular heartbeats might suddenly detect heart palpitations and faulty blood circulation upon exposure to a Freon leak. The blood circulation problems may also lead to numbness in the limbs.
General Illness
  • A Freon leak can cause nausea, headaches, bouts of regurgitation and general disorientation. Confused thinking and trouble walking or coordinating movements also may result. Severity of illness depends on the amount of Freon released and the length of time exposed. A fire department can provide solutions and guidance for anyone detecting a Freon leak and suffering from its effects.
  • 2helpful
    2answers
    Type of gas in air conditioner
    Your car uses the new refrigerant, R-134.
    Refrigerant required for
    can't tell exactly, too many variables, your low side pressure should be about 50 - 60 lbs, ( this is merely a guide ) temperature affects this reading. a simple way to tell is add freon and watch you indoor coil if possible. when the entire coil is sweating you are full. if only partial sweat is visible add more, a little at a time, it takes several minutes for this to circulate.
    Top Nor-Lake Refrigerators Experts
    ZJ Limited
    ZJ Limited
    john h
    Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
