Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
