If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Your vehicle's On-board diagnostic (OBDII) computer will have stored the applicable fault codes.
Have your computer scanned by your local Mazda dealership (or approved agent) for these codes, which will immediately identify the circuit/component causing this condition.
OOPS dealer only ,Try opening and closing door lock three times drivers side 10 sec interval between clicks then try starting if no go then dealer only
