I assume you mean the timer ? If so :http://customer.honeywell.com/techlit/pd...I assume you mean the timer ?
If so : http://customer.honeywell.com/techlit/pdf/69-0000s/69-1038.pdf
You can't post conmments that contain an email address.
Manual 4 Wire Premium Baseboard/Line Volt Thermostat
Compatible with 120, 240 and 277 vac baseboard heat systems
Simple dial-type mechanical control
Quantity
store iconPick Up In Store
Unavailable at Guam - Tamuning Check Nearby Stores
package iconWe'll Deliver It to You
UnavailableDelivery is unavailable for this product
Your local store: Guam - Tamuning Store Details & Services
Accessories (1)
Product Overview
The easy-to-install Honeywell Manual Electric Baseboard Thermostat works on 4-wire (double pole) electric heat applications (baseboard or line volt) and allows for simple, worry-free operation. It has a simple dial-type mechanical control and is UL and CSA listed for safety.
You will need Adobe® Acrobat® Reader to view PDF documents. Download a free copy from the Adobe Web site.
Compare Similar Non-Programmable Thermostats
Price
$21.99/each
$24.97/each
$44.28/each
null¢ /null
Name
Double Pole 4-Wire Line Voltage Mechanical Thermostat
Digital Non-Programmable Thermostat
Single-Pole 10.4 Amp 120/240-Volt Digital Electronic Non-Programmable Wall Thermostat in White
Brand
Lux
Honeywell
Cadet
Honeywell
Ratings
View ProductView ProductView ProductView Product
Specifications
Dimensions
Product Depth (in.)
1.5
Product Height (in.)
4.5
Product Width (in.)
2.75
Details
Color Family
Whites
Color Family
White
Operation Type
Mechanical
Returnable
90-Day
Shape
Rectangle
Thermostat Product Type
Thermostat Shape
Rectangular
Thermostat Type
Heat Only
Voltage (v)
110/240v
Voltage (volts)
110/240
Warranty / Certifications
Certifications and Listings
1-UL Listed,CSA Listed
Manufacturer Warranty
1 year limited warranty How can we improve our product information? Provide feedback.
The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Hi, You need to reset the t-stat and totally reprogram it... Look in your manual how to do that or...
online...
I looked at site on the internet that sold the programmer that I wanted, and one of them had a free downloaded manual, so I printed it off and it was perfect!
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
