Bissel Proheat 2X Cleanshot won't spray soap. I bought the cartpet cleaner a few months ago and I just opened the box to clean my floors. When I turned the cleaner on, the spinning dial on the top of the base was not spinning. The directions say that if the dial is not spinning, the soap or water is not coming out. The soap DOES come out when I use the hand held cleaner, but when I switch back to the main unit, the soap comes out for a minute, then the dial stops spinning. If I switch back to the hand held after this, the hand brush does not spray soap. I think I've had it too long to take it back to the store, please help!
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. [email protected]
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
You need to change the belt(s). You can find the belts for this model here.
http://www.vacbelts.com/bissell-proheat-belt-combo-pack.htm
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
