SOURCE: I need to take nth (8,5,4,etc) root on the TI30XA
7th root of 3.4 x10 (exp) 23
Solution:
Try it.
Have I solve your problem?
Thanks,
-engrkoiled-
SOURCE: nth root button on it89
There is no nth root button per se. But to take the nth root of a number is equivalent to raising the number to the power 1/n
Nth root of X= X^ (1/n)
Hope it helps.
SOURCE: how to find nth root using Casio FX-83ES
You use the power root function key accessible with the key sequence [SHIFT][X ^]. I am inserting a screen capture from the manual to show you the sequence.
On the third line of the capture (power root) is the key you must press. In the small rectangle to the left of the radical sign you enter the order of the root: 2 for square root, 3 for cube root, 4 for 4th root and son on.
To calculate the decimal log you use the [LOG] key as shown on capture. For natural log (ln), use the [LN] key. The argument (2/3) in your example should be enclosed inside the parentheses.
