Question about Kidkraft Toys
I have the KidKraft 72 Piece Activity Tool Bench, and need to replace some of the screws that have gotten worn down over the years. I contacted KidKraft and they are willing to replace the parts, as long as I can name the parts from the assembly instructions, which I don't have and can't find. Help!
    Top Expert:
  • Kidkraft Master
  • 51,327 Answers
Request the assembly instructions from KidKraft so you can identify the parts you need to order.
Posted on Jan 20, 2018
5 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: Need assembly instructions for Baby Einstein
Contact the company and they will send you instructions or you can go on their website to see if they have them on there.
Posted on Aug 05, 2009
SOURCE: I need assembly instructions for Battat activity
Where did you get the battat activity bus?
hygo@aol.com
Posted on Aug 24, 2010
jyackle5
  • 8197 Answers
You can get the manual on the link below.
http://www.kidkraft.com/_media/assembly-instructions/65182_usa_copy1.pdf
http://www.kidkraft.com/assembly-instructions/
Good Luck
Posted on Dec 23, 2010
  • 6 Answers
SOURCE: Hi, I lost my assembly instructions
Here is a link to the direct download of the instruction manual for the KidKraft 17836 Ride Around Town Train Set, in PDF format:
www.kidkraft.com/_media/assembly-instructions/17836.pdf
Thanks for using FixYa!
Posted on Jan 10, 2011
How to change the seals on a clutch master cylinder for a 98 Subaru outback
It's been years since I have rebuilt a clutch master, since they have gotten so cheap, but if you really want to do this, first tear down the unit and lay all parts out in order to aid in reassembly. Next, inspect the bore of the unit to see how bad it is. It badly scratched or pitted, stop and replace the entire unit. If it looks ok, hone the bore with a hone tool using clean brake fluid, clean with more clean fluid, and install new parts using assembly lube. Bench bleed, then install and bleed the system.
May 14, 2016 | Subaru Cars & Trucks
IS THERE A VIDEO HOW TO PUT TOGETHER A KIDSKRAFT SUPER MODEL DOLL HOUSE?
Hi
I didnt manage to find a video for the assembly but I did find a fairly decent image that may help as well as a detailed assembly (although you may already have this) sheet. You could try contacting Kidcraft as they do have assembly videos for their other dollhouse models.
Links Follow, trust this helps, best regards Alan.
Image ---> https://s-media-cache-ak0.pinimg.com/originals/fe/83/d9/fe83d925edb56790435f588120d13247.jpg
Instructions ----> http://www.kidkraft.com/_media/assembly-instructions/65827_intl_revised_copy5.pdf
Kidcraft contact page ---> Customer Service
Feb 13, 2015 | Toys
My sons Nabi won't charge and I don't know if it's the charger or the Nabi's battery help me
Contact Nabi. I have had several issues with nabi. Most likely the slot where the plug is placed is disconnected inside somehow. You can try placing the charger in the freezer for about an hour. There is a thermal fuse that over heated that will reset it. Nabi sent me a new tablet twice. They have great customer service.
Dec 01, 2014 | Kidkraft Best Quality Outdoor Storage...
Can't find a bench seat for 88 bronco
I saw some bronco bench seats on ebay, they are expensive. I just did a web search. Other than that, I don't know? Call around to some salvage yards?
Jan 22, 2018 | 1988 Ford Bronco
I need assembly instructions for Circo 120 piece train set
Hello, I found this link on the kidcraft.com website. It brings up the 5 pgs that were in the box, nothing extra. Hope this helps.
Dec 20, 2010 | Kidkraft Circo Construction 70pc. Train...
My Makita bench grinder has four holes to change the grinding wheel..how to I get the retaining nut off as I don't have a tool to fit the four holes?
Make your own wrench out of a piece of wood stock,with 2 screws or nails spaced out to 2 opposing holes in the retaining ring/nut.HarborFreight sells a 'spanning wrench' online .
Jun 30, 2010 | Makita Nip 5"(127mm) Bench Grinder Wheel...
I think there is something going on between 1 or more of the three buttons namely "SEARCH,SCAN,TRUNK" that won't let me use the trunk system automatically. I have to use it manually .Worked great for 3...
Yep, sounds like the contacts on the keypad are worn. In most cases i have been able to resolve that issue here on the bench. Let me know if you'd like to ship it in. Dodgem250.com
Mar 30, 2010 | Uniden BC898T Base Scanner
Not cutting right - or at all
Depending on how much use the saw has gotten over the years the problem could be a very dull blade, worn out motor brushes, or a nearly worn out motor. The danger is that a power tool that is not working as it should is much more hazardous than a newer saw that is working properly.
May 21, 2009 | Saws
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
I need instructions for assembling the 101 Piece Deluxe train set
Here is the URL for Kidkraft's site. You should be able to find what you need there.
http://www.kidkraft.com/assemblyinstructions.asp
Jan 15, 2009 | Kidkraft 101 Piece Deluxe Train Set
Toys Logo
135 people viewed this question
Top Kidkraft Toys Experts
ray gallant
ray gallant
Tom Chichester
susan carrera
susan carrera
Level 1 Expert
Are you a Kidkraft Toy Expert? Answer questions, earn points and help others
