The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
SOURCE: sentry safe S3877 have key and know combination but battery dead
Our safe had a philips screw at the bottom of the keypad (facing downward), not a paperclip hole as some do. To replace batteries, unscrew this setscrew and twist the face gently. Replace the 4AAs and reinstall faceplate/fingerpad. Should work.
