If you see error code F21 on your Whirlpool washing machine, this refers to a water drain problem. The washer won't be able to finish the cycle and your laundry will be wet. This error code means draining is taking too long, and something is wrong with the water pumping.
Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
The F21 error on a Whirlpool Duet washer means the unit was draining slowly. This can be caused by a blocked outlet hose (kinked hose, for example), excessive suds from using non-HE detergent or too much detergent, blockages in the drain pump filter (coin catcher), or a problem with the pump.
You should be able to clear the error by pressing Pause/Cancel twice. Check your outlet hose. Then unplug the washer. Have a bucket handy to catch the water when you access the pump. Remove the toe panel from the bottom of the washer. There are three screws to remove; then you need to lift the panel slightly and pull it forward.Check the filter for foreign objects.
Test the washer by selecting a cycle and running it with no clothing or detergent. If the unit still fails, then the pump, pump motor or the pressure switch is bad. However, you should also check the wiring to the unit.
I hope this helps. Please add a comment with the model of your washer for specific directions and parts information.
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
The "F21" error code indicates it takes too long for water to pump out of the tub. This can be caused by using too much High Efficiency detergent or using too much of the wrong kind of detergent. This error code can also be caused by debris clogging the drain pump. Is the error continues after you clean the filter, then you will need to replace the drain pump with this new one.
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
