AEG Lavamat 72640 Front Load Washer Logo
Posted on Dec 06, 2010
Vélin losar sig ekki við
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
149
Points
ég átti við sama vandamál að stríða en komst að því að kolin í mótornum voru búin. þau kostuðu um 10 þús. í b.ormson fyrir ca. 6 mánuðum. ath að það þarf að rífa mótorinn úr til að skoða eða skipta um þetta.
3helpful
2answers
Electrical problems headlights come on and so do whipers automatically
This problem is being caused by a switch called the multifunctional switch. This switch is located in the steering colum . This switch controls the wipers ,turn signal and low and high beam. Replace the the switch and this should fix your problem. FYI check the connectors that go to the switch for burn marks. If burned repair the connector also.
Hope this helps ! Mr Toofix.
I need to find a supplier for MagFormers but I need the supplier to be close to Denmark. The supplier should be apple to give me like 50 or 100 pieces
Hej Kik ind hos os på www.toymaster.dk - vi har 13 forskellige æsker. Hvis du skal bruge 50-100 af samme slags, finder vi helt sikkert en pris, så du også kan lave en fornuftig forretning. :-) / Peter TOYMASTER.dk
BROTHER AX 410 DAKTÄ°LONUN KILAVYESÄ°
Go to brother.com, click on support, poke around there you will find a manual.
DickyO
Missing of defective cartridge lexmark-120n не...
replace chip on the cartridge or replace cartridge with new one
неÑ? звÑ?ка в наÑ?Ñ?никаÑ?...
Sorry, i'm not able to view your problem.
I'm getting viewed it as:--
Generic problem for all Cellular Phones
не&#2
ð½ðµñ? ð·ð²ñ?ðºð° ð² ð½ð°ñ?ñ?ð½ð¸ðºð°ñ? ð° ð·ð½ð°ñ?ð¾ðº ð¿ñ?ð¸ññ?ñ?ññ?ð²ñ?ðµñ?
What did you mean?
Aug 05, 2010 • Cell Phones
1helpful
мой Rikoh Aficio
First, σ╖σσ▲→ßßφ, then you have to ╪╫╓╓ƒä☺c╟☼☼├☺♣☻☻♦.After 4 times with step 1, do step 7 times.
What are the front toe in parameters for Hyundai Tucson?
Wheel & Tire
Wheel alignment
Front
Rear
Dimension
Toe-in
Camber
Caster angle(to ground))
King pin angle
King pin offset mm(in.)
Side slip mm(in.)
P215/65R16
0°±0.2°
0°±0.5°
3.53°±0.5°
12.77°±0.5°
-9.73(0.383)
±3(0.118)
P235/60R16
0°±0.2°
0°±0.5°
3.53°±0.5°
12.77°´±0.5°
-10.41(0.410)
±3(0.118)
P215/65R16
0.37° ~ 0.41°
-0.92°±0.5°
±3
P235/60R16
0.37° ~ 0.41°
-0.92°±0.5°
±3
Wheel
Size
Run out mm(in.)
AL wheel
6.5JX16
Radial : 0.3(0.01), Lateral : 0.3(0.01)
Tire
Size
Inflation pressure kg/cm² (psi)
P215/65R16, P235/60R16
2.1±0.07(30+1.0)
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
