JVC GR-SXM245 S-VHS-C Analog Camcorder Logo
Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know what Cassette for this model jvc gr-sxm245
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Dec 06, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218974
Points
3782
You can use VHS-C (C for compact) or S-VHS-C cassettes. The S-VHS-C is Super-VHS, for better quality recordings, but there isn't that much in it compared to digital. I'm assuming your camera has the S-VHS capability, as the title, otherwise stick to VHS-C.
JVC Camcorder GR-AX2 error code E04?
The error code E04 on a JVC Camcorder GR-AX2 indicates a problem with the cassette mechanism. This could be caused by a number of issues, such as a jammed cassette, a malfunctioning cassette compartment, or a problem with the camcorder's loading mechanism. In order to fix the issue, the camcorder may need to be serviced by a professional. In the meantime, you can try removing the cassette and reinserting it to see if that resolves the problem.
good luck
I have an ancient JVC GR-sxm320 can't find the Manuel and can't open the cassette door.
There are two reasons normally that the cassette door won't open when you slide the Eject button on the JVC GR-SXM320. One: the camera uses a powered eject feature. If the battery is low and the AC adapter isn't plugged in and powering the camera, this doesn't work. Two: if the LCD monitor screen is not open to more than a 60 degree angle, then there is an interlock that keeps the cassette door closed. This avoids the door hitting the screen. It's best to have the monitor at a 90 degree angle to the camera body when you open the cassette. Press Stop if there is a chance that the camera is recording to the current cassette.
JVC has the manual here: http://resources.jvc.com/Resources/00/00/97/LYT0465-001A.pdf .
Note: since the camera is older, check that the AC adapter is getting warm when it's plugged in and connected to the camera. This checks if the adapter is working. Check if your battery pack is good. If you have the BN-V856U battery pack, you need the AA-V80U charger to charge the battery. The charger that came with the camera will not work.
Third party battery packs and chargers are still available for the GR-SXM320. Use the manual to look up the part number and Google for the battery or use the camera model number to find available parts. For example, a replacement BN-V11U battery is available at Amazon and here: https://www.bestbatt.com/JVC-BN-V11U-BN-V12U-BN-V14U-BNV-V18U-Battery-p/bbbnv11u.htm .
I hope this helps.
1helpful
2answers
What is a cassette name of this model
Cassette utilized in JVC GR-D770 camcorder is calls MiniDV
Ask for MiniDV tapes for this camcorder.
1helpful
Unit in safeguard mode remove and replace battery 01
SURE ITS NEED SERVICE YOU CAN TAKE TO ANY AUTHERISED SERVICE CENTRE.
BEFORE THAT MAKE SURE THE CASSETTE IS NOT STUCKING INSIDE THE MECHANISUM. THERE SHOULD BE AN ERROR CODE ON THE DISPLY UNIT START WITH E-01 TO E-06
I have a jvc digital camera GR-D350 u i don't know how to get the cassette in?
How do I change the GL- DPF8005A Digital piture frame from chines to English.
1helpful
2answers
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
6helpful
3answers
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
1helpful
3answers
Looking for a used/broken jvc GR-D290EKP camcorder
I have a jvc gr-d290ek digital camera which is not working due to cassette being stuck in the unit. Are you still looking for a used or broken camcorder of this kind?
How to use A JVC
go to the link below and download a manual, if your model is not listed another one may be similair. http://www.jvc.co.uk/download.php?type=2
1helpful
JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
