Motorola Mobility H700 Wireless Headset Logo
Posted on Jun 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't hear headset
Hi, i've been following the instructions on the website and leaflet, and the phone is paired (at least it says so in my blackberry 8310). but it doesn't ring, when i dial a number on the phone, nor will it turn blue (most of the time) or when it does - it flashes slow blue, but nothing can be heard.  please help. i can't ring 1877motoblu very quickly - thanks. karin
  • phkhan2001 Feb 13, 2009
    i have similar problem with my Nokia 6300 and Bh 320 blue tooth head set.
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Motorola Mob... Master 1,001 Answers
  • Posted on Nov 26, 2016
wwlvictoria
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603878
Points
6027
  • Charm sonic Universal Bluetooth headset for Apple iPhone 6/5s/5c/5, iPhone 4s/4, Samsung Galaxy S5/S4/S3, PC Laptop, and other bluetooth device;
  • Deep Sleep mode extends battery life;
  • Noise-cancelling microphone reduces background noise;
  • Fits comfortably in either ear with a super soft gel ear tip;
  • Super easy and fast paring with your smartphone or other Bluetooth device.
https://www.amazon.com/Charm-sonic-Bluetooth-Headphones-Microphone/dp/B01H6D7P7O/ref=sr_1_6?srs=14423925011&ie=UTF8&qid=1480130604&sr=8-6
Anonymous
Level 2:
Scholar:
  • Expert 77 Answers
  • Posted on Jun 28, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
77
Questions
0
Helped
20195
Points
188
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    How do I pair my nokia 3109c mobile phone with my motorola h720 bluetooth headset - it just keeps saying "failed" when I try.
    Hi Sue Clay,
    Please use the following link to access to the user manual of your H720: http://bit.ly/1DyhSmE, on page 5 you can find how to pair the device, if the "failed" message continues, use the instructions on page 13 to reset the device.
    Regards,
    Lester S.
    Motorola Support
    Problem with Blackberry Pearl 8100
    Did you try deleting all devices paired and then try pairing again?
    1helpful
    I cannot pair my new Blackberry Bold 9650 to my Blue Parrott Expressway. Any suggestions.
    Hi Joe-
    While you are pairing the headset and phone you want to turn off any WiFi or Data/Internet Connections your phone may be running. These applications can cause interference during the pairing process. We also need to make sure the Xpressway is going into pairing mode. From the OFF state hold the unit up to your ear. Press and Hold, the Multi Function Button (Biggest of the three buttons) until you hear a total of 6 tones. You will first hear 2 tones (keep holding the button) there will be few second pause (keep holding the button), you will hear 4 additional tones. Once you've heard all 6 tones the MFB should be flashing blue very quickly, like a strobe light - this is the pairing mode for the Xpressway. Have your phone search and when it locates the device it should call it by name VXi, Xpressway. Highlight and select the unit. If the phone asks for a pass code type four zeros, 0000. If the phone asks if you want to add or pair with the device select "yes". If you continue to have issues please call us 800-742-8588 for additional help.
    3answers
    How do I connect my blackberry cel phone to my bluetooth ce0678
    Hi, you can use this instruction to pair your blue tooth with your cell phone:
    Instructions
    Pair Your Blackberry with a Bluetooth Headset
    Turn on Bluetooth headset and Blackberry hand-held.
    Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
    Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
    Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
    Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
    Use your Bluetooth Headset with your Blackberry
    Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
    Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    Press the on/off button on your headset to end a call or use the end button on the handheld.
    Tips & Warnings
    Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
    Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
    Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
    Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
    Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
    Good luck to you..
    Feb 01, 2011 • Cell Phones
    2answers
    My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
    Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
    You can use the below steps to know how to pair properly:
    Instructions
    Tips & Warnings
    Hope it helped.
    Thanks for usingf ixya..
    Can i use my plantronics 230 bluetooth for my blackberry phone?
    Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
    How to pair a phone to a blue tooth device?
    Instructions
    Pair Your Blackberry with a Blue-tooth Headset
    Turn on Blue-tooth headset and Blackberry hand-held.
    Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
    Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
    Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
    Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
    Use your Blue-tooth Headset with your Blackberry
    Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
    Press the on/off button on your headset to end a call or use the end button on the hand held.
    Tips & Warnings
    Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
    Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    How do i pair motorola h670 with blackberry torch
    Please kindly follow the detailed solution provided below;
    STEP 1 Put on the motorola h670 by pressing and holding the switch button for 5secs,afterwards you will hear a click followed by a blinking of blue lights,by now the headset is in pairing mode.
    STEP 2 Activate the bluetooth radio on your blackberry torch,by clicking on the menu>set up>bluetooth>search.
    STEP 3. After searching,your torch will find the motorola h670 in the list of found devices.click on it,afterwards a message will display saying "pairing complete".
    By now your blackberry torch has been successfully paired with your motorola h670 headset and you are good to go.
    Take care!
    Configuring motorola bluetooth with blackberry
    Hi
    Following the steps how pair your head set with blackberry
    1.With the headset off, hold the Multifunction Button until the LED remains on (about 2 seconds).
    2 Perform a device discovery from the phone.
    3 When the scan is complete, the phone displays the devices found.
    4.Select the Motorola HS805 from the discovered devices list and confirm following the on screen prompts.
    When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
    Thank You
    25helpful
    5answers
    What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
    Guest
    Rank:nonexpert_s.gif Apprentice
    Rating: 0%, 0 votes
    Pair Your Headset
    Before using, you must pair your headset.
    1. Turn phone on.
    2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
    3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
    HS04VXX”Headset and prompt you for a passkey pin.
    4. Enter “0000”.
    5. Press OK on phone.
    6. From Headset device list press “Logitech HS04VXX” Headset.
    7. Select connect.
    When your Headset is successfully paired, the blue LED will flash slowly.
    115helpful
    12answers
    How do i connect my bletooth h350 to my phone
    Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
    Top Motorola Mobility Radio Communications Experts
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
