My ZR200 sometimes works and sometimes doesn't. the battery freezes.
My son dropped my camera sometime ago and at first it wasn't working. It was a white background. Well, sometimes it works and sometimes it doesn't. the battery has been freezing sometime. Is the battery dying or is the camera itslf have a problem. sometimes it works when it feels like it.
likely that the internal connection is loose. basically the camera just sits on a bed of contact points and a drop/knock may dislocate the points. get it fixed professionally.
Is your new battery charged? You may need to place it in the charger or hook the camera to the AC power and leave it overnight. If you have a charging cradle try to charge the battery that way. Sometimes that arrive dead.
The laser lens on the camera might need cleaning. Use a q-tip and 90% alcohol to clean it, then try it. If that doesn't help, try another disc. If that doesn't work, I'm afraid it might require servicing. Get a quote before you get it serviced, sometimes it's just better to buy another one. Good luck!
I have found that my aiptek digital camcorder also freezes like this sometimes after I have pressed the button to stop recording a movie. You are right that sometimes you must remove the battery to unfreeze it, but I have found a couple of other tricks that work sometimes.
1. You can hold down the menu button for a few seconds (like 6). Sometimes this kicks it into the menu and unfreezes it.
2. Sometimes using the power button inside of where the screen stores to turn it on and then off again often helps.
3. Popping the digital card out (push in so it unlocks, then push it right back in) also helps unfreeze it for me.
If those don't work, pop the battery out again.
I do find that every few months I need to clean the connection points on both my battery and the camera where the battery clicks in. After I do this it behaves much better for a couple months. Good luck.
1). Download all you pictures on the memory card onto your computer and format the memory card. This will enhance the performance. Its possible too much pictures are there on you memory card and therefore the camera performace drop and hangs.
2). Clean the battery terminals as well as the terminals on your battery and fully it charge it.
Try the above and let me know if the problem still persists.
I bought this model several months ago and it was working great up until Christmas time. For some reason it just stopped working. I couldn't get it to turn on OR sometimes it would turn on after several attempts. I kept changing the batteries and sometimes that would work, but it was more or less random successes. I found this link on FixYa :
http://wwwuk.kodak.com/global/en/service/batteries/batteryDigCamChart.jhtml?camera=C813 I was using generic batteries (Philips) which I bought in bulk from a discount tech store and these batteries were working in the camera since I bought it. The batteries were new; just generic. By coincidence I ended up buying KODAK branded alkaline batteries from the same store. I replaced the older generic ones with the KODAK batteries and the camera came back to life! I'll leave it off for a day and see if it turns on tomorrow.
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
try tapping side by side, it always works!
