SOURCE: Amilo Pro v2055 Sound very quiet
Go to control panel then sound and audio devices then speaker volume and see what level it is set on.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
SOURCE: AMILO pro v2055 Shuts down not long after starting up
Sounds like it could be a ram issue. Rule of thumb for blue screenis to check the ram first
SOURCE: Hi when I turn on my fujitsu amilo pro v2055 it
The operating system software is stored on the hard disk. The computer cannot detect the hard drive and therefore cannot load the operating system. It could be that it only needs reseating to get it operating again, if that does not work it could be a faulty disk drive or a faulty disk controller.
To test if the hard drive is OK, remove it and connect it to an USB hard drive adapter and plug this adapter and drive into a working computer's USB port. If this computer see this as an external hard drive and you can view the contents of this drive, then it is OK. If you cannot see this drive then it is faulty.
You need to replace the hard drive in your computer and install Windows again to get an operating computer again.
SOURCE: where can I obtain a schematic diagram for the
You can't. I've never seen schematics offered by any manufacturer for their laptops (or desktops, for that matter), even to warranty service centers. The boards were never intended to be serviced to component level, just replaced as a single part.
When I worked at a shop full-time servicing laptops we had some success at repairing boards with power problems where it was possible to trace out the circuits and identify bad parts. But most of the time all we could do was change the board.
SOURCE: Fujitsu Amilo Pro V2055. Starts boot, performs
This usually means 1 of a few things..
1. Your Harddrive is bad
2. You got a boot sector virus, and your boot ini file is so badly infected, your computer can't find the boot file and you need to format your c:\ or d:\ drive....if you can get to your CMD window (command) but the way you bring it up is from CMD in start/run/CMD but since you can't even boot to your desktop...then you can choose a few options..
IF you have your your Windows Xp, or Windows Vista or Window 7 (depending on how you purchased your system, I'm thinking XP...since with Vista and Windows 7 you can reload to factory settings)
If you do have the disk....then you WILL have to reload your Operating System ....IF your harddrive isn't bad (have bad sectors or clusters) or is just "old" or was bumped severely and there's a dent on your harddrive preventing your boot ini file from being found...
There are so many things that could be wrong with it....Send me more infomation....
It's definitely NOT your motherboard...it's a harddrive issue...whether from a virus (which there are many out there that could infect or even rename your boot file....or your harddrive is BAD..
Either way...let me know and I can help you further!!!
