press the on/off button and then select General, the phone will ask you if u want to change from offline mode and allow network access..i need more info to help me help u ;) good luck !
Only thing I can think of.. is that maybe the phone is set to use UMTS only and not GSM?
Try looking under:
Menu / Tools / Settings / Phone / Network
And see if the option for Network Mode is set to GSM or UMTS or Dual Mode.
If it is set on UMTS try changing it to GSM and see if it will then connect to the network. The Dual Mode option should allow it to switch between the two automatically. I prefer setting my phone to GSM as it will help save on battery power.
just click on the switch off button and you can change it to online mode. Offline mode is generally present for in flight operation, also known as IN FLIGHT Mode.
I couldn't find the above menu items however i found an alternative: press the on/off button on your E71 and select General. The phone will then ask if you want to change from offline mode and allow network access.
Try the following steps. I fixed the same problem on my E71 with these.
1. move the sms which can not be sent into the draft box.
2. switch the phone to offline mode.
3. enter draft box, and send the sms
4. after the notification of "saving into sending box..", power off the phone.
5. turn on the phone again, select "no" for the question, then, wait several second, u can see the sms is sent.
You've probably selected the "offline" mode on your phone. To get the phone to access the network again, go to the idle mode of your phone, then press the power switch of your phone ONCE, then select any profile.
Ex: meeting
It'll then display a message like " phone is currently in offline mod. Change profile to access network?"
