Coleman 10' X 10' Sundome Tent 9160K101 Logo
Posted on Dec 06, 2010
Looking for set up instructions for a Colemen 14x9 Stockton Tent
1 Related Answer
shiiiro
  • 4 Answers
  • Posted on Jun 03, 2009
SOURCE: im looking manual instructions for coleman Sahara tent
Go on youtube, you will find some excellent videos on how to....on a range of tents. I saw the coleman sahara tent on a video last year as I was considering buying one! Good luck!
How do I set up the Alpine hicker biker tent 925-204 SKU
I do not have access to specific instructions for setting up the Alpine Hicker Biker Tent 925-204 SKU. However, I can provide some general tips for setting up a typical backpacking tent:
  1. Find a level and flat spot to pitch your tent. Avoid areas with sharp rocks or roots that could damage your tent.
  2. Lay out the tent body on the ground and attach the poles according to the manufacturer's instructions. Most tents come with color-coded poles and sleeves to make setup easier.
  3. Assemble the poles and insert them into the pole sleeves. Make sure the poles are properly aligned and the tent is taut.
  4. Stake down the tent at each corner using the included stakes. This will help secure the tent to the ground and prevent it from moving or tipping over in windy conditions.
  5. Attach the rainfly to the tent body, making sure that it covers the entire tent and is properly tensioned.
  6. If your tent has a vestibule or gear storage area, set it up according to the manufacturer's instructions.
  7. Once the tent is set up, test it for stability and make any necessary adjustments.
It's important to read the specific instructions that came with your Alpine Hicker Biker Tent 925-204 SKU before attempting to set it up. Different tents may have unique setup procedures or additional features that require specific instructions. If you have any questions or concerns about setting up your tent, it's best to contact the manufacturer for assistance or consult with a professional camping equipment retailer.
Pitching instructions for a great outdoors executive 320 tent and sunroom
This is a duplicate of a previously asked question on FIXYA from 2012, where an exact set of instructions could not be found, but two proposed answers were given.
For a similar but not the same tent, the scanned document still exists online:
https://drive.google.com/file/d/0B1SdA-vKLONwZ05vTGZKdF9BTzQ/view
https://www.fixya.com/support/t7407226-need_pitching_instructions
Quoting from FIXYA question from 2012
Wollocks
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
[email protected]
How do i find the instructions to set up a western field tent from Montgomery wards
instructions to set up a western field tent Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do you set up Montgomery Ward Western Field tent
https://answers.yahoo.com/question/index?qid=20090705144031AAE0SOM
Setting up Vintage Umbrella Tent wmv
western field tent from Montgomery wards Google Search
Distance from Stockton tx to midland tx in miles
Rather than give you the answer, let me tell you how to find the answer (very easily) yourself.
Go to www.maps.google.com and then search for either one of the two cities you're looking for. Say for example you search for Stockton, TX.
Once you find Stockton (Fort Stockton), then zoom out the map until you have both cities displayed.
Now place your mouse cursor directly on top of Stockton then RIGHT-CLICK - a drop-down box will appear and one of the options available is "Measure Distance", so LEFT-CLICK on 'measure distance' and you will see that a small black circle has just been placed on Stockton. Now move your mouse cursor over to Midland and LEFT-CLICK on Midland.
Voila! you now see the distance (as the crow flies) displayed on your map. Wasn't that easy?
6helpful
2answers
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
4helpful
3answers
Im looking manual instructions for coleman Sahara tent
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
