Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
When a cooling device starts beeping, see it as a warning it can't hold the temperature you selected. Could be the compressor does not work correct, could be it lost cooling fluid. If it keeps beeping, save the food by putting it in another fridge and start (or let someone start) finding out what is wrong. The door symbol is indicating the fridge thinks the temp rise is caused by an open door.
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now But no beep Yay!!!!
go to your electrical panel and kill the power to the fridge for a few minutes, or pull the plug whichever is easier. this will recycle the alarm mechanism and often solves the beeping problem
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
